Random question…I was replacing the red fixtures for the trim piece that goes over the glove box. On disintegrated and bits fell into the hole. Is there anyway to fish them out? Don't know if that area is accessible if I take apart the glovebox. I can hear the pieces rattling around.
Haven't taken a dash out before, but I would think that those pieces would fall out if the glove box is removed.Originally posted by duracellttu View PostRandom question…I was replacing the red fixtures for the trim piece that goes over the glove box. On disintegrated and bits fell into the hole. Is there anyway to fish them out? Don't know if that area is accessible if I take apart the glovebox. I can hear the pieces rattling around.
Hoping there is an obvious solution to this that I haven’t found yet….Anyone have a solution for finding replacement nut inserts for the front carbon/Kevlar bumper reinforcement bumper pins? Looks like they are NLA, and the only option is likely buying a damaged used reinforcement just for the clips..
07129901748
Prestol-cage
ST6,3-ZNS
1 Photo
thanks for the info, appreciate it.Originally posted by jayjaya29 View PostUnfortunately as far as I know, there are no suitable alternatives:
https://nam3forum.com/forums/forum/m...rvoir-mounting
I used a hardware store spring nut aka speed nut although I think technically "speed nut" is the wrong term for these. Looks just like the below, has worked great and even reused them a few times so far.Originally posted by skylinekin View PostHoping there is an obvious solution to this that I haven’t found yet….Anyone have a solution for finding replacement nut inserts for the front carbon/Kevlar bumper reinforcement bumper pins? Looks like they are NLA, and the only option is likely buying a damaged used reinforcement just for the clips..
07129901748
Prestol-cage
ST6,3-ZNS
When I went to a Euro bumper there was a guy on Ebay selling these, likely not OEM, but a nice copy, but tight fit and worked perfectly.Originally posted by skylinekin View PostHoping there is an obvious solution to this that I haven’t found yet….Anyone have a solution for finding replacement nut inserts for the front carbon/Kevlar bumper reinforcement bumper pins? Looks like they are NLA, and the only option is likely buying a damaged used reinforcement just for the clips..
07129901748
Prestol-cage
ST6,3-ZNS
I just searched BMW prestol cage bumper or something like that, I want to say they were gold in color.2004 Silbergrau Metallic 6MT
Thanks for the suggestion! I’ve been checking eBay and no luck yet. I did find some damaged bumper reinforcements with all the clips and such still intact so I’ll just likely do that to get the hardware and trash the damaged bar.Originally posted by Cubieman View Post
I think if someone is looking to replace the washer fluid/horn mount clips they could toss the self tapping bolts and use M6 bolts instead with part number 37146850307 Prestol-Cage (M6 Zns3) which has an M6 nut insert and is still available to buy…but for the bumper pins since those are self tapping thread this idea won’t work (sharing in case someone else runs into this issue).
