Originally posted by Will
Keep us posted if you end up replacing the amp. I really want to upgrade the factory sub setup but keep the HK basket. I was considering just upgrading the 6x9s like you tried, and wondering if there is a way to replace the small amp with an aftermarket one using the same wiring (with larger power and ground) or if you have to use a line converter and RCA cables etc.
Quick engine bay picture I snapped today of the Karb CSL race intake I've just installed.
I'm running a modified CSL program on my stock MSS54HP. I'm using a 1 bar Bosch MAP sensor (matches the original scaling factor ) that I plumbed into the brake booster hose under the cabin filter tray.
The only thing I have left is to install is the CSL specific dipstick/tube once those items makes it stateside; for now I have the bung in the oil pan blocked off and the digital oil level indicator enabled in the cluster.2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bavsound / BlueBus / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / ZCP Brakes / Yellow Tag Steering Rack / Karbonius CSL Race Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / Modified Bilstein B6s / Eibach Springs / Staggered OE CSL Wheels / 265 & 235 Pirelli PZ4s / SunTek 38% Carbon Tint
- Likes 6
Test fitted v1 of 3D printed brackets to hold the amplifier. With the Xtrons head unit I don't need the 6CD changer and Bluetooth module, and also don't need the big mounting rig that goes with it. I could spend $75 buying the BMW item but according to RealOEM it weighs half a kg, these brackets will weight a fraction of that and hold the amp in the original location and orientation.
Sent from my iPhone using Tapatalk2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
- Likes 7
Nice!!!Originally posted by karter16 View PostTest fitted v1 of 3D printed brackets to hold the amplifier. With the Xtrons head unit I don't need the 6CD changer and Bluetooth module, and also don't need the big mounting rig that goes with it. I could spend $75 buying the BMW item but according to RealOEM it weighs half a kg, these brackets will weight a fraction of that and hold the amp in the original location and orientation.
I won't be replacing the amp. There's a couple threads that discuss the amp in HK cars and, if I recall correctly, there's no plug and play solution like there is for the non-HK audio cars. Perhaps you can refer back to the Rockford Fosgate thread, and the other stereo / amp threads, some members were discussing other potential speaker replacement options for the 6x9 subs in the basket. If you try one of those, please update us with your experience with them. Thanks.Originally posted by Ramps View Post
Keep us posted if you end up replacing the amp. I really want to upgrade the factory sub setup but keep the HK basket. I was considering just upgrading the 6x9s like you tried, and wondering if there is a way to replace the small amp with an aftermarket one using the same wiring (with larger power and ground) or if you have to use a line converter and RCA cables etc.Last edited by Will; 01-08-2024, 08:37 AM.
The headers bolted up perfectly. For example, they easily slid on the studs; no pressure was required to push the headers in position against the head, nor were there any sounds or vibrations from the flanges that you would hear if they were scraping on the threads.Originally posted by bimmerfan08 View Post
How'd the headers bolt up? Fitment issues?
At Section 1 of the exhaust, the connections were better aligned than original headers. The welded flange aligned properly.
Same experience, Megan's for the win!!Originally posted by OldRanger View Post
One of my favorite M3's, everything about it. Don't ever get rid of these wheels. (If you do, you know who to sell them too, I'm on standby for you)Originally posted by 9kracing View PostDropped it off to Dennis @ SVBimmer to have my topside reinforcement done, and a few other odds and ends.
Bi-LED projector retrofit!
IG: @limited.slip
Alpine White 1 Series M Coupé
T̶i̶t̶a̶n̶i̶u̶m̶ S̶i̶l̶v̶e̶r̶ E̶3̶9̶ 5̶4̶0̶i̶ M̶-̶S̶p̶o̶r̶t̶ T̶o̶u̶r̶i̶n̶g̶ S̶6̶2̶ 6̶M̶T̶
- Likes 6
