    Alright, back on the road. Feels like a brand new car internally. Engine, suspension, interior done and now, the exterior.
    Dynavin 9
    BavSound Stage 1
    Recaro Sportster CS
    Complete black interior swap
    Brought over my Aluminum trim
    Euro short console
    PedalHaus aluminum pedals
    Latvian Steering Wheel Alcantara
    AKG Bronze/Delrin Brake and Clutch bushings
    Repaired GM5
    Cluster MT insert
    I LOVE THIS CAR!
    Sent from my Pixel 9 Pro XL using Tapatalk
      Click image for larger version  Name:	IMG_9344.jpg Views:	3 Size:	191.8 KB ID:	281747 Click image for larger version  Name:	IMG_9348.jpg Views:	3 Size:	211.7 KB ID:	281748 Took it out for a joy ride. Running the Bryson mullet tune... The S54 is such a manic animal!
      IG: @limited.slip
      Alpine White E90 M3 6MT
      Alpine White 1 Series M
        New inserts for the Pole Positions
          Wow that looks good
            So my 2004 red convertible of 12 years and 173K miles was totaled in September by a motorcycle. I picked up a 2006 Carbon Black convertible with 119K miles. Here are some items I have done over the last month to freshen it up and bring it up on maintenance.
            Center console refresh
            Stock shifter knob
            ECS front brake rotors
            Trunk struts
            Hood struts
            Missing plastic fasteners all over the car
            New headlight trim
            New End Links
            New Valeo Starter, no crank no start
            ICV cleaned
            Engine bay TPS Sensors
            New Temperature Sensor
            New Guibo
            New CSB
            New Rogue Transmission mounts
            Exhaust hangers
            Fuel Filter​
              Are you going to do rear seat and door inserts too?
                Well, I did this last week, but forgot to post. Finally my last interior piece for the time being, refinished by none other than Alex...100% satisfied as usual.
                  I wasn't planning to. I think that would be a bit much. I liked having fabric seats and I wanted to break up the all black interior after I swapped in the black trim. I also like the flexibility to change the inserts again down the road if I wanted. I might pick up a spare dash trim set and cover it in houndstooth for fun.
                    3.5L Stroker Engine Build Prep...
                    Arrow Precision Crankshaft 97mm
                    Arrow Precision Rods
                    CP 12:5.1 Pistons
                    Schrick 288/280 cams w/ rocker arms
                    Supertech Valvetrain w/ lash cap conversion kit
                    Bored 87.5mm block
                    Diff Lab engine girdle kit
                    Slight port work and valve job on the donor cylinder head
                    All new bolts, accessories, vanos, etc..!
                    Radium fuel system upgrades - rail, lines, filter
                    Walbro 485lph fuel pump
                    Bosch 550cc injectors
                    eFlex Fuel Pro e85 kit
                      Over the last 2 weekends:
                      Oil Sensor
                      Oil Change
                      CPV O-Ring
                      Replaced fuel pot rubber
                      Front convertible top fixes
                      - motor replaced (noise),
                      - motor gears replaced with brass,
                      - front motor cover replaced,
                      - added missing rubber isolator screw
                      Replaced cracked Mount F/Wind deflector clips (cost left kidney)
                      All Pulleys and Tensioners replaced
                      Replaced alternator
                      Dynavin HVAC relocation bracket
                      Fixed Clock adjustment/Instrument cluster​ (https://www.ebay.com/itm/174414757236)
                        Started working through an OEM navigation retrofit (I know, there are better units that require no effort to install) and found this little guy tucked away behind the dash.
                        Anyone want it?
                          Anyone want it?
                          I had one of those!!! Ended up causing a glitch with my turn signal blinker so I removed it. Not to suggest yours is bad or anything, I think mine developed a fault. I have the original install instructions in pdf if anyone needs it.
                            Car went in last week to the indy shop I've used for years for a FR suspension refresh at 86k miles after having noticed the front just felt "loose"; all original parts were still on the car at this point.
                            Replaced: LCAs, FCAB, sway bushes, sway links, rebuilt yellow tag rack and new steering coupler.
                            Encountered another issue during alignment, so had new Turner adjustable LCAs, the outer lower ball joints and sway links replaced (bushes done 2 years ago with all new diff bushings). Can't wait to drive this thing, getting it back tomorrow. I'll say, just handling the old parts, it is amazing how much difference in play there is compared to the new stuff.
                              Not an M3 but my E39 is all I have left for my old BMW fix. Got a new Brembo GT kit front and rear installed on the car which solves all of my many complaints about the stock brakes. It’s overkill maybe but this was my treat for selling my E46. Ignore the filth, the car is living outside temporarily while I have some construction done on my house.
                                A little bit of magic eraser and I think I can hold off on a Coby wheel refresh for another year ..
