    Perfect. I had an exhaust shop just rig a little hanger up and it popped right on. And let me tell you, it's a lot easier to fit a 14 lb section 3 than a 50+ lb one. 😉
    that's why they only use one hanger on the left side compared to 2 on steel units. It's so light.
      Very true. Just wanted to say thanks for the info on FB that you gave me about Shipnerd. Made getting the exhaust shipped over to me much cheaper. 👍🔥
      Instagram: @logicalconclusion
        Fantastic. Glad to have helped.
          Originally posted by A144 View Post
          Car has about 113k miles, and I believe these are the original bearings.
          Interesting to see the shorter and deeper wear on #6 compared to #4 with longer wear pattern. I believe #4 bearing is a better match for the journal (tighter clearance) which distributes the load over a longer arc, while a wider clearance tends to concentrate the load at narrower arc on the bearing.
            I had these AN fittings installed when I had my diff built. So when I decided I wanted to add a diff cooler / temp sensor, I would be ready for the install. However one of the AN fittings had began to develop a small leak.
            That custom ramped Drexler LSD 😎
            Also got around to installing a CSF oil cooler. Much bigger than stock
            sigfinal22
            IG: @marcdavid038
              Interesting idea, I hadn't thought about it like that before. I used ACL bearings, so we'll see how they look in another 100k!
              Sent from my SM-G975U using Tapatalk
              2006 M3 6MT Interlagos Blue
                Ordered a Bluebus.
                  Swapped injectors and fuel pump to convert the M3 to E85. Very worth it. 👍
                    Originally posted by MD_M3 View Post
                    Harness out
                    Sent from my SM-N986U using Tapatalk
                    race car build?
                      race car build?
                      Yes. I'll be running in NASA ST4 this year
                      sigfinal22
                      IG: @marcdavid038
                        Just curious, who did the scaling/tuning after the swap?
                          Hassan @ HTE Performance. I'm just running a basemap right now, haven't even started dialing it in yet. Fuel pump relay just died so replacing that and installing wideband.
                            Don't suppose there's a chance you're running a CSL airbox? I've been wanting to do this for my car, but have been waiting to see if it's worth the ~$1500
                              Cleaning loctite from female threads...for the 3rd time.
                              1st try= Lang bolts and loctite 242 factory torque spec
                              2nd try= Lang bolts and loctite 243 factory torque
                              3rd attempt will be: Lang bolts with loctite 243 (maybe 263 red) and a higher torque spec., 12ft lb instead of 9ft lb.
                              I am sure it would have been just fine on my first attempt.
                              .22 cal gun cleaning brushes work well.
                              I am so nervous that I have to cheat (bias the crank slightly CCW of TDC1) the timing for the bridge to sit flush on the head I am scared to start the car so part of this is me just stretching out the time it's going to take before the first turn of the key.
                              Instead of "bulletproofing" my vanos which worked just fine and already had the updated cam bolts (didn't know until disassembly) I feel like I am going to ruin my engine somehow, fingers crossed.
                                I'm running an Eventuri intake.
                                Fuel pump = $105ish genuine
                                Injectors = $180
                                Tune = $350
                                I feel about 10-15 whp more on the butt dyno throughout the powerband. Once fine tuned I'm guessing it'll make 20-25 whp in various spots throughout the powerband over 91 tune. I'll dyno mine at EAS sometime to compare against everyone else in SoCal.
