I kept the OEM studs with my SS headers.
This is a sticky topic.
If you plan on reusing the stock studs, make sure they are fully threaded into the block before installing the new headers. They can come out slightly when removing the nuts.
There aren't too many one time use things. I think this is all there is:- Block to header gaskets
- SAP gasket
- Section 1 to section 2 gaskets
- Header nuts
- SAP nuts
- Section 1 to section 2 nuts
- Reinforcement plate bolts
I would stick with the original exhaust studs, just make sure they are tight like heinz said. If any of the studs come out which is very likely make SURE you clean the threads of the head well with compressed air as you will likely not ever find a 7mm thread chaser for whatever reason.
Take great care in re-installing the head studs, a mechanic told me a bit of anti-seize was important to use on the studs but others on here have argued not to do that. I personally would recommend a small amount to prevent galling.
The N54 studs are nice in that you can use a tool on them in order to make sure they are bottomed out but the extra length makes it such that you must postion the headers to mate w/ the studs further out from the head and with very little room between the head/inner fender area it proved to be quite challenging for me to install the SS headers compared to the Euro headers. Maybe some of that was factory vs. aftermarket fitment.
Always use OEM BMW gaskets on the headers.2004 Silbergrau Metallic 6MT
Thank you! All of those are on the list. What about the 3 rear muffler hanger bushings, and 2 S2 bushes--mine are original to the car.Originally posted by heinzboehmer View PostIf you plan on reusing the stock studs, make sure they are fully threaded into the block before installing the new headers. They can come out slightly when removing the nuts.
- SAP gasket
- Header nuts
- SAP nuts
You can see all those bushings (mirror will help) without removing anything on the car, so might be worth taking a look at them to see if they need replacement.Originally posted by PSUEng View Post
Thank you! All of those are on the list. What about the 3 rear muffler hanger bushings, and 2 S2 bushes--mine are original to the car.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
maybe for extra peace of mind to have it stainless in case of debris. I upgraded mine because it was old.Originally posted by ridebikes View PostStainless steel clutch lines...... worthwhile or snake oil?"your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
Can anyone school me on what is needed for an E85 setup? Does it need a special fuel pump or filter.. anything else? Also, if I fill with E85 and it doesn’t get used much, will it damage anything? The car I purchased has an APE setup and I’m trying to figure out what kind of maintenance it may require.
Typically E85 needs more volume vs. gasoline, so a larger fuel pump with more flow and bigger fuel injectors are needed.Originally posted by racee78 View PostCan anyone school me on what is needed for an E85 setup? Does it need a special fuel pump or filter.. anything else? Also, if I fill with E85 and it doesn’t get used much, will it damage anything? The car I purchased has an APE setup and I’m trying to figure out what kind of maintenance it may require.
E85 isn't great for sitting around as the alcohol tends to absorb water. I don't think a month or two will do too much but for longer term storage/sitting, it's probably better to do it with a full tank of gasoline or add fuel stabilizer"your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
I am going to be needing a new fuel pump and I am planning on getting the radium engineering kit as a replacement for the OEM (SC plans in the future). I was gonna be going with the Walboro 255 but I saw the AEM pump for E85 is only an extra $25. http://www.radiumauto.com/Fuel-Pump-...6-M3-P314.aspx (http://www.radiumauto.com/Fu2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Currently sitting with a dilemma. Have a 2002 AW/Cin manual car with 185k miles, of which 13k are my ownership. It’s an amazing and engaging car. Traveling a lot these days and only really have time to drive it once every 10 days with everything else. Not a perfect car either, could use some bodywork.
I also have a brand new Karb intake sitting in my basement. Debating on whether to 1) Sell the car 2) Sell the intake 3) Install the intake.
Option 3 is obviously pretty involved and likely adding another $1k in expenses (filter, install kit, DME upgrade, tune).
