Whats this module behind the drivers side c-pillar? My assumption is related to the radio antennae and rear glass defroster? My car doesnt have radio and my defroster has never worked, am i ok to unplug and remove this?
You're correct - Amplified Radio Antenna Module.Originally posted by BigRussia View PostWhats this module behind the drivers side c-pillar? My assumption is related to the radio antennae and rear glass defroster? My car doesnt have radio and my defroster has never worked, am i ok to unplug and remove this?
Wow! I was hoping for your sake it was just a pricing error (I just purchased Genuine for $10.99/ea about 6 weeks ago) but unfortunately ECS has them inflated too at $29.95/ea.Originally posted by SQ13 View PostWhy the fuck are these header gaskets $39 each now? Can elring be used here?
https://www.fcpeuro.com/products/bmw...-11627830667-2
FWIW, when I was researching SS header install, all sources I found said to go with Genuine gaskets granted "cheaping out" on Elring was the difference between $10, not $200.
Yeah..I’ve always used OE gaskets. FmlOriginally posted by mtpktz View Post
Well I need to hit this thread again lol...
For front skid plate removal, is this to be done ONLY with the front end supported and NOT weight on wheels? Or is it acceptable to remove the plate with weight on front wheels? The correct method will impact how I get this thing up in the air for header install. I've read that one should only do this without weight on wheels; as far as needing alignment afterwards, I'm unable to find definitive answer. Bentley manual does not say anything either way other than don't drive without it.
Thanks!
I bought mine from FCP for that same price a few weeks back. But to be fair, all other retailers were $30+ at the time. I did score my Bosch O2 sensors from AutoZone with free drop ship from Bosch and 20% off over $100--hands down the best price I found.Originally posted by mtpktz View Post
It doesn't matter. Everything that plate bolts up to is solidly mounted to the chassis of the car. Can remove and reinstall with the wheels on, wheels off, car in the air, car on the ground, etc. No need for alignment either.Originally posted by PSUEng View PostWell I need to hit this thread again lol...
Thanks!
More details/discussion: https://nam3forum.com/forums/forum/m...on-jack-standsLast edited by heinzboehmer; 07-24-2022, 02:46 PM.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Is my AC low on refrigerant? I'll fire up my car and no cold air blows out the vents. However, once I start driving, it'll get cold."your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
I'd say it's low if you notice that the far left vent is colder than the far right.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Off the ground like the car would be at a shop or bmw dealer.Originally posted by PSUEng View PostWell I need to hit this thread again lol...
Thanks!DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Is you AC fan working (the electric pusher in front of the rad and condenser)? Sounds like the condenser is not getting airflow (until you start moving) and thus not cooling the hot refrigerant.Originally posted by zzyzx85 View PostIs my AC low on refrigerant? I'll fire up my car and no cold air blows out the vents. However, once I start driving, it'll get cold.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I'll have to check that out.Originally posted by Tbonem3 View PostI'd say it's low if you notice that the far left vent is colder than the far right.
I'm positive it is working as I can hear it from inside the car lol. It also happens in the morning when the car is "cold".Originally posted by heinzboehmer View Post
Is you AC fan working (the electric pusher in front of the rad and condenser)? Sounds like the condenser is not getting airflow (until you start moving) and thus not cooling the hot refrigerant."your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
Ah, well low refrigerant is likely then. What tbone suggested is a quick way to check.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
