Dumb question: if structural foam injection was previously done many years ago for the rear subframe, is it still possible to do any further reinforcement with any of the current solutions?
Just no welding.
So you can do rivet style (rear and front points) or a GTR style brace or 6 point.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
"eldor" lol try some lord of the rings magic spell and maybe they'll start working again.
Try reseating them? Misfire can be other issues though, plugs, knock sensors.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Cubieman View PostWhat would be a good type of grease to use for seat rails? Don't want any lingering smell etc.
I am in the process of cleaning up some old rusty seat rails and used a lot of brake clean trying to remove as much of the factory grease as possible as it was full of gritty debris.
Also, bonus points for application techniques as you can't get the center sections packed with grease very easily.
Originally posted by zzyzx85 View PostLeft for work this morning and the TPMS, Brake, and DSC light came on while I was driving slowly through the parking lot. A quick search says it's might be the steering angle sensor acting up? I just got to work and haven't checked to see if it's still there.
edit: went back to the car, fired it up, and no more lights. it was rainy this morning so maybe the belt slipped?
Mike02 M3 Titanium Silver / Black
11 Tundra SuperWhite / Black
Is there a way to remove the positive battery terminal on the passenger side in engine bay? Trying to install my strut bar without dropping the suspension but the terminal is in the way.
2007 GX470
build/journal
ig: @zzyzx85
Originally posted by zzyzx85 View PostIs there a way to remove the positive battery terminal on the passenger side in engine bay? Trying to install my strut bar without dropping the suspension but the terminal is in the way.
Youtube DIYs and more
Here’s a dumb question, how do I reset an air bag light? Bought the car with drivers side door airbag light on. Car was in an accident at some point so I assume from that, however replaced the air bag but can’t seem to figure it out.
Took it to a bmw shop and they tried but it came right back. Could it be something else?
Originally posted by Liverpoolreds8 View PostHere’s a dumb question, how do I reset an air bag light? Bought the car with drivers side door airbag light on. Car was in an accident at some point so I assume from that, however replaced the air bag but can’t seem to figure it out.
However, if your came back there is likely a fault with the system. One common issue is a broken retainer for the airbag connectors. There are little fingers on the clip that when seated actually push the contacts together in the connector. If one is broken, there will not actually be a completed circuit and the system will flag it. If yours had a replaced airbag that would track. Person who replaced it might have damaged the retainer. 20 year old plastic can break really easy.
Previous owner of mine did a window regulator and must have broken a clip in the process. I got a few from a junkyard e46 to replace it and have a spare or two.
To confirm, disconnect battery, pull the door panel off and check the connector. Hard to describe how to remove them so google is a must here. Sorry.Last edited by Lee_Enfield; 01-19-2023, 01:04 PM.
Originally posted by Lee_Enfield View Post
You need specific software to clear them. Inpa for example. There are a few sources for the download around the forums.
If that’s the one that would trigger it then it must be that because I noticed it was broken but it seemed to clip in just fine
You’re talking about the actual connection to the airbag correct? It’s a small black connector that sort of slides in at 90 degrees if I remember.
Check out this thread for pics.
https://www.e46fanatics.com/threads/...#post-18711443
