Does anyone know where I can find replacement headliner door trims? The current ones on my E46 are spent after the original owner did a slipshod DIY headliner replacement. I got a new headliner installed however the upholstery shop I used couldn’t replace them and just glued the existing ones back on.
yeah but super ghetto. Drive the car, brake hard and engage ABS, bleed the car. Keep doing it and you'll have flushed it out by some pointOriginally posted by Nate047 View PostIs there a way to do an ABS module bleed without using INPA?
Personally, I use the Schwaben tool (foxwell) as it has various operations like this. Pretty cool, just press some buttons, bleed that corner, then move to the next and it will engage abs each time.
Last edited by Tbonem3; 02-26-2025, 02:22 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
0-60motorsports calling you in here
So I wrote last week that I went for a spirited drive on a relatively hot day with no crank fan... SMG COG light came on, car revved in 3rd gear but I had to limp off the freeway. Turned the car off, waited a few minutes, turned it back on and managed to get to my first destination. I returned home, SMG COG light came on, I pulled off the freeway and waited an hour for the car to cool down. Drove home without issue.
Pulled codes and came up with these:
36 (0x24) Auswertung Positionsgeber Waehlwinkel
37 (0x25) Auswertung Positionsgeber Schaltweg
Quick Google searching has led me to the conclusion that the GPS (gear position sensor) needs to be replaced, but just wanted to know if anyone else has experienced these symptoms. I can hear the accumulator prime properly when I open the driver's door (about 8-10 seconds) and the gears seem to shift fine when the car does indeed shift and not die.
Today was interesting in that the car died shortly after starting and testing the shifts... car was on for about one minute when everything died, battery light was red, oil light was red, etc.
Thanks in advance!
Bumper mounting drama.
2004 M3. Front bumper was a little misaligned so I took it off to re-fit. Discovered the four mounting studs (part #17) that screw into the carbon crash bar were missing. Odd?
Ordered those. Installed them with the spacers on the middle two, no spacers on the outer two.
Bumper goes on, fits well, but will not click into any of the four studs with any reasonable amount of force. I feel like I'm going to start doing damage if I press harder.
I lightly sanded them to take off the very slight edges from production, gave them some light grease. Still no go.
Grease marks on the bumper sockets line up enough that some of them should go, but no.
Tried to press the stud into the bumper socket on it's own and it won't go.
Anyone else experience this? Is the culprit just the 20yo rubber not flexing at all?
Thinking about taking ~1mm off the studs so they slip in easier. As is, they are 15mm OD on the studs and 12.5mm id for the receiving socket.
I don't know this for a fact, but it may point you in the right direction. I believe that these are made to be fairly modular. The base of it seems to act like a modular cage so you can add and remove switches/buttons. The face plate comes off the front which allows access to the switches.Originally posted by M3LSB.Gab View PostAnybody can help me find that PN for this module ? without heated seats and HK button. thanks in advance !!
My gut feeling is that you can do this:
buy a switch panel that has 3 buttons on it. LINK
remove/steal the face plate from that one
remove the face plate from your factory one. remove the switches you don't want (LINK showing the guts)
re-arrange buttons to your liking
install face plate from the second switch panel you purchased LINK
code??
Maybe someone else can chime in on this.
Funny timing - exactly same thing that happened to me a few weeks ago. I have a GPS on the way from bmwfnatic.Originally posted by davidinnyc View Post0-60motorsports calling you in here
Thanks in advance!
Sent from my iPhone using Tapatalk2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
Glad to know we’re experiencing the same things. I ended up buying a GPS and new detent springs / sleeves / etc. since I’ll be down there. I should probably also change out the CSB, guibo, tranny mounts…Originally posted by karter16 View Post
My understanding is that this was the case in earlier manufacturing years (you can actually see on early model cars that the panel face plate is segmented to allow additions/removals. BMW then changed to have different part numbers for each combination of buttons with a single faceplate. Subsequently I believe they discontinued these and if you buy one today it has all the buttons and you have to put blanking caps over the buttons that don't apply.Originally posted by Avedis View Post
code??
If you have a latter year car I believe the only option is to find a second hand module in the exact configuration you're after. If OP has earlier model year and thy can source the switches they need they will be able to do as you say.
The late style switch center is still (sorta) modular: https://nam3forum.com/forums/forum/m...087#post246087Originally posted by karter16 View Post
Sent from my iPhone using Tapatalk2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
ah good stuff - thanks for that clarification. So theoretically all you need is one that has all the buttons, take out the ones you don't want and face plate to match.Originally posted by heinzboehmer View Post
The late style switch center is still (sorta) modular: https://nam3forum.com/forums/forum/m...087#post2460872005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
ahh yeah it makes sense ! Mine is a ZCP 2005 with manual non-heated seats, no HK so it's suppose to have only 3 buttons from factory but I guess last owner changed it and it has the full 7 buttons now, even for the rear sunshade. I guess I just need the cover plate letting 3 holes for DSC, tire pressure, Sport.Originally posted by Avedis View Post
code??
Maybe someone else can chime in on this.Last edited by M3LSB.Gab; 03-07-2025, 06:10 AM.Instagram : @gc.m3sg
2023 M3C Xdrive British Racing Green
2003.5 M3 Silver Grey 6 speed
______________________________________________
Miles End Composite CF CSL front bumper/Diffuser/Trunk
ST Suspension/CSL Rotors/Full Magnaflow exhaust
BBS RSII/Avant-Garde CSL Reps
