    1. inspect/refresh all bushings. OEM for street. Avoid poly. Monoball for track use.
    2. Ensure you have a good alignment done. I had high speed sweeping corner issues and it turned out my rear toe was setup by an idiot (the previous owner)
    3. 200tw tires are fun in the summer but wear fast! Can’t drive them in the winter in many climates.
    4. if you get sway bar keep rear oem. stiffer rear sway isnt necessary. some racers don’t even run a rear sway
    Man's in LA, there are no seasons.
    Ball joints in the RTAB is fine for street, so are solid rear subframe mounts from what people have said. KW CS is pretty... stiff.
      Drove him hard, filled up the gas tank, then washed him. Came home, pulled onto the tire cradles for his winter hibernation, then hooked him up the trickle charger. Good night, sweet prince.
      Cheers,
      Cody
      '04, manual, Dinan Stage 1 suspension and engine flash.
        Cheers,
        Cody
        c’mon man these cars are the best in the fall. Enjoy her another month.
          You guys are freaking me out with these gender assignments.
          Next think you know you'll be naming your cars (please don't).
            16 years and my car still doesn't have a name... She does identify as a bad bitch though lol
              Yea I have pretty much a full Powerflex catalog and Clubsports on my E36, my assumption is that same treatment would be a largely similar experience on the E46. That's not really what I want for this car though. I might actually go with a softer spring before I put the coilovers on. Bushing wise, I will have to think about it for a bit still because I want to do the job once if possible. I don't want to have to redo it a year later if I hate the choices I made lol. Also peoples opinions on what constitutes "too harsh" varies a lot lol. I had my alignment done pretty recently and I don't have any reason to believe it's been thrown out, but of course that is possible.
                God help me, I ordered a carbon fiber roof. 🤦‍♂️
                MVP Track Time
                  Found doing that operation much easier than I anticipated.
                  Pneumatic gun for the chassis glue and window glue is a big time help 😉
                  Gesendet von meinem LON-L29 mit Tapatalk
                    What'd you end up getting?
                      This is amongst the least necessary things I've done, but I've swapped out all* of my fuses for Littelfuse SmartGlow fuses. Idea is if the fuse blows, an LED will light up. Littelfuse is the OEM fuse manufacturer for BMW as well, so not cheap chinese junk. Now I can count on my hand the number of times I've actually blown a fuse, but still figure with an aging car it'll probably save me some trouble shooting in the future.
                      *Well almost all; they don't make a 40A glow fuse, so I have one that wasn't replaced. And I had to buy the 7.5A pieces separately.
                        Just dropped off my car to Performance Technique for this list of parts going in,
                        VinceBar Epoxy and Rivet kit
                        Turner underside reinforcement plates
                        CMP Subframe Bushings
                        CMP RTABs
                        Turner Rear Camber Arms
                        Hotchkis Front Sway Bar
                        ST XTA Coilovers
                        All OE/OEM bushings, bearings, diff cover, and rubber front and rear
                        This is number 2 of the big 3 once the work is completed. Last is a Blackstone Labs test once I do the oil change, that will determine if I jump on rod bearings immediately, or give me time to collect some parts. Cams, Karb airbox, and a tune is in the near future. Getting my build journal updated here. Click image for larger version
                          I hope so. It will be a Winter project. Guys' gotta have something to do when the snow falls.
                          Lightest available was Lang.
                          Now about the 25 pounds I need to take off my personal chassis??!! 🤦‍♂️
                          Feff
                          MVP Track Time
                            Sweet. I was planning on RKP. Really want Karb but the shipping will crush those dreams. Will look into Lang some more, I've only casually looked.
                            That might be the cheapest yet most difficult way to drop pounds from the car. Costs less to feed the monster in my tummy, but damnit if doesn't he get pissed in the process.
                              Karbonius vented engine cover and Mishimoto electric fan:
Name:	Engine Cover & Electric Fan.jpg
                                Installed my cooling pipes and belt system. Changed out the transmission detent pins and springs.
                                Waiting for the clutch to come in the mail tomorrow.
                                My new oem CSL trunk that I purchased shipped out today too😁
