Didn't do it myself, but had the clutch and flywheel replaced, along with all the normal "while you're in there" parts - pilot bearing, pin, throw out bearing, rear main seal, all hardware. Original parts had 142k miles on them including a lot of track miles so I'm happy to have it done. Clutch pedal feels strangely smooth and a bit lighter.
What's the difference between US and Euro parcel shelves?Originally posted by E36 PWR View PostAudio delete, new euro parcel shelf and new c pillars going in
2003 E46 M3 Titanium Silver / Black
www.instagram.com/nextlvel
- Likes 3
Ceramic reduces head dissipation roughly by 20%. Thermal insulation reduces dissipation by 70%.Originally posted by Cronenberged View Post
Does this perform better than ceramic? Just curious of the choice
By the way, they are also ceramic coated 😂
Wrapping with insulation tape ist almost the same in terms of reducing head dissipation. This is a bit better. Also since there is sheet metal around, stuff doesn't get in between and start rotting. Also, If you ever get oil on taped headers, the smell will never go...Originally posted by Nate047 View PostYea why exactly are you doing that? Is wrapping them not good enough?
Started having some goofy AC blower fan speed modulation, so I did the FSR today thinking maybe that fixes it. I replaced original unit with the ACM brand part. I'll say that the new one has shorter "fins" so it goes in easier than the original one comes out (hits the actuator rod on the little motor thingy in the way), but the housing shape isn't quite the same (plastic v. metal) so it takes a bit to get it seated; looks same as the $200 OE part so figure WTH. The fat plug was a PITA to get off, AND re-seat; don't break the little motor thingy in the way; best to unplug it first and if you have a long T-20, all the better. Other than that, it works, hoping not to have to do this again--replacing glove box and foot bulbs while I'm in there. I always like comparing the old parts to new, seeing what's different, how they cut cost, etc.
EDIT: Drove around today and I noticed more air is output at the vents, and the AC feels cooler. Interesting.
Turned my Antigravity LiFePo4 into a paperweight over winter storage because I had too much faith in the low voltage cutoff and never found time to visit the car and put it on a tender … 2.7V across the terminals and won’t charge at all. New battery time, deciding between a CSL sized AGM or another 40 Ah lithium.
On the bright side the car started right up after jumping it with no odd noises or problems after eight months … always a win!
edit: decided to go with this one: https://powertexbatteries.com/produc...motive-battery
Nothing special about the Antigravity over any other LiFePo4 really. Cells are all sourced in China since they have the materials and the BMS is mature off the shelf tech. Really if you look at the cost of the cells themselves these batteries are all a ripoff .. they all have like $50 or less worth of lithium in them. I can stomach $450 compared to $270 for the CSL sized AGM though.Last edited by repoman89; 06-18-2023, 12:53 PM.
I wonder if you can bring that battery back to life by opening it up and charging the individual cells/banks back up. Wouldn't be surprised if the voltage is too low to power the BMS and that's why the battery isn't charging.Originally posted by repoman89 View PostTurned my Antigravity LiFePo4 into a paperweight over winter storage because I had too much faith in the low voltage cutoff and never found time to visit the car and put it on a tender … 2.7V across the terminals and won’t charge at all. New battery time, deciding between a CSL sized AGM or another 40 Ah lithium.
Nothing special about the Antigravity over any other LiFePo4 really. Cells are all sourced in China since they have the materials and the BMS is mature off the shelf tech. Really if you look at the cost of the cells themselves these batteries are all a ripoff .. they all have like $50 or less worth of lithium in them. I can stomach $450 compared to $270 for the CSL sized AGM though.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I sent them an email earlier asking if they could. Thought about doing it myself but the lid is pretty epoxied in place and I don’t want to hack at it. Voltage too low for the BMS was my thought too, assuming it can’t power itself from the output terminals since I put ~13V across them for quite a while.Originally posted by heinzboehmer View Post
My understanding is lifepo has a good shot of recovery with a degraded state of energy storage so I’ll see what they say.
My other idea if I was to hack it apart myself anyway was to just replace the cells themselves .. like I said before it’s only like $50-75 worth of lithium (<400 Wh)Last edited by repoman89; 06-18-2023, 07:11 PM.
