    Originally posted by cornerbalanced View Post
    Going to feel like a completely different car when you go for the first canyon rip. Red on white looks amazing!
    Thank you! Might be a while before a proper rip is in store. I discovered some rust on the floor, and a stripped out bolt provision in one of the RTAB pockets. So I have to basically limp the car about 1/4 mile down the street to the new house (moving in a week). Then once we are settled in, I'll need to get it into a shop to get the two issues fixed. I just hope it doesn't turn into one of those months long repairs.
      Got the rear end and a lot of the suspension in yesterday.
        Picked up new O2 sensor. Finally fixing it running lean and misfiring.
ID:	254888 Click image for larger version
ID:	254889 Click image for larger version
          Finally got the Fall Line Motorsports bar back from iND and put it in the car!
ID:	254892 Click image for larger version
ID:	254893 Click image for larger version
            To say the sparco pilot barely fits would be an understatement! This is with it as low as it will go on the Mounts, obviously no slider, and with the euro headliner without the bump. Tall guys have it rough, still don't wish I was shorter though 🤣
              Wernd if you wanna trade cars mine has an extra few inches not running a headliner.
                Does it mount bolted to the floor or to the seatbelt mounting points?
                  Three holes drilled into the car each side. It's an exact fit so some of the seam sealer BMW has at the joints needs to be razor bladed and removed. For instance where the b Pilar meets the floor or the back seat panel meets the floor. At least mine did for the bar to sit all the way down on the floor.
                    Rear brakes are all in, driveshaft back in, dangerously close to being drivable 😳
                    Things that are left are basically heat shields, put the exhaust back on, bleed the brakes, and then do the final torque on everything at the right load. Then I just need to throw a seat in it and creep over to the new house lol. Luckily it’s literally 2 minutes down the road.
                    Guys, just a word to the wise, don’t fucking decide to move right when you’re in the middle of a big project. 🤣🥹😵‍💫
                      Standalone ECU arrived. Came together with a plug and play wiring harness adapter. I will also upgrade O2 sensors to the newer Bosch LSU 4.9 and a K Type EGT sensor. Since my engine is heavily modified I decided to go this route as I can switch on the fly between maps and I can get a race traction control programmed in for wet track conditions. Should also allow for a bit more power to be squeezed out vs a tune stock ECU.
                      I'll try to sum it up once I am done and have results.
                        about 1 week away from purchasing another M3 E46 after selling an Alpine/Cinnamon E46 M3
                        it was SMG though. new car will be a 6 SPMT.
                          Originally posted by Altaran View Post
                          Where/how are you planning to mount all of this?
                          Email to [email protected]
                            The EMU is smaller than the MSS54, so it will simply go in it's stead. The lambda to can and the vanos addition are small and fit besides.
                            So it all fits perfectly in.
                              The EMU is smaller than the MSS54, so it will simply go in it's stead. The lambda to can and the vanos addition are small and fit besides. So it all fits perfectly in.
                              I'd be curious to see it installed, looks like it'll be interesting to package.
                                Originally posted by Ramps View Post
                                Keep us posted if you end up replacing the amp. I really want to upgrade the factory sub setup but keep the HK basket. I was considering just upgrading the 6x9s like you tried, and wondering if there is a way to replace the small amp with an aftermarket one using the same wiring (with larger power and ground) or if you have to use a line converter and RCA cables etc.
                                Yes, there is a way! I just completed upgrading the stock AMP, HK sub speakers, and all remaining HK speakers. I aslo integrated full touch screen carplay to the oem navigation HU.
                                So there is a stage 2 oem amp upgrade available that boosts the stock amp to 50 watts. You have to send the stock amp out to the UK so they can modify it. Kicker makes direct replacement speakers that drop into the HK sub basket and uses the exact same connections as factory. All of this is essentially plug-n-play drop in and there is a significant upgrade in sound.
                                Kicker vs OEM HK Sub Speaker
                                Click image for larger version  Name:	IMG_5550_jpg.jpg Views:	0 Size:	69.5 KB ID:	255767
                                OEM Navi HU with touchscreen & fullscreen carplay.
                                Click image for larger version  Name:	IMG_5610_jpg.jpg Views:	0 Size:	75.6 KB ID:	255768
                                Kicker Speakers inside the oem HK sub basket...
                                Click image for larger version  Name:	IMG_5556_jpg.jpg Views:	0 Size:	103.8 KB ID:	255766
                                2005 BMW M3 - Interlagos Blue
