Originally posted by cornerbalanced
Thank you! Might be a while before a proper rip is in store. I discovered some rust on the floor, and a stripped out bolt provision in one of the RTAB pockets. So I have to basically limp the car about 1/4 mile down the street to the new house (moving in a week). Then once we are settled in, I'll need to get it into a shop to get the two issues fixed. I just hope it doesn't turn into one of those months long repairs.
Does it mount bolted to the floor or to the seatbelt mounting points?Originally posted by Wernd View Post
Three holes drilled into the car each side. It's an exact fit so some of the seam sealer BMW has at the joints needs to be razor bladed and removed. For instance where the b Pilar meets the floor or the back seat panel meets the floor. At least mine did for the bar to sit all the way down on the floor.Originally posted by Nate047 View Post
Rear brakes are all in, driveshaft back in, dangerously close to being drivable 😳
Things that are left are basically heat shields, put the exhaust back on, bleed the brakes, and then do the final torque on everything at the right load. Then I just need to throw a seat in it and creep over to the new house lol. Luckily it’s literally 2 minutes down the road.
Guys, just a word to the wise, don’t fucking decide to move right when you’re in the middle of a big project. 🤣🥹😵💫
- Likes 4
Standalone ECU arrived. Came together with a plug and play wiring harness adapter. I will also upgrade O2 sensors to the newer Bosch LSU 4.9 and a K Type EGT sensor. Since my engine is heavily modified I decided to go this route as I can switch on the fly between maps and I can get a race traction control programmed in for wet track conditions. Should also allow for a bit more power to be squeezed out vs a tune stock ECU.
I'll try to sum it up once I am done and have results.
- Likes 9
Where/how are you planning to mount all of this?Originally posted by Altaran View Post.
Email to [email protected]
The EMU is smaller than the MSS54, so it will simply go in it's stead. The lambda to can and the vanos addition are small and fit besides.Originally posted by George Hill View Post
So it all fits perfectly in.
I'd be curious to see it installed, looks like it'll be interesting to package.Originally posted by Altaran View PostThe EMU is smaller than the MSS54, so it will simply go in it's stead. The lambda to can and the vanos addition are small and fit besides. So it all fits perfectly in.
Yes, there is a way! I just completed upgrading the stock AMP, HK sub speakers, and all remaining HK speakers. I aslo integrated full touch screen carplay to the oem navigation HU.Originally posted by Ramps View Post
Keep us posted if you end up replacing the amp. I really want to upgrade the factory sub setup but keep the HK basket. I was considering just upgrading the 6x9s like you tried, and wondering if there is a way to replace the small amp with an aftermarket one using the same wiring (with larger power and ground) or if you have to use a line converter and RCA cables etc.
So there is a stage 2 oem amp upgrade available that boosts the stock amp to 50 watts. You have to send the stock amp out to the UK so they can modify it. Kicker makes direct replacement speakers that drop into the HK sub basket and uses the exact same connections as factory. All of this is essentially plug-n-play drop in and there is a significant upgrade in sound.
Kicker vs OEM HK Sub Speaker
OEM Navi HU with touchscreen & fullscreen carplay.
Kicker Speakers inside the oem HK sub basket...
2005 BMW M3 - Interlagos Blue
BBS - Recaro - MCS - PFC - Powerhouse Amuse - Supersprint - Karbonius - RKP - YFCM - DMG Autosport - Diffsonline - Autosolutions - Mile End Composites
- Likes 3
