Rebuilt the steering coupler with CMP solid coupler to replace the worn and soft OE one. Easy project that's made a big difference! Definitely recommend for RHDs!
Sent from my iPhone using Tapatalk2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
- Likes 3
How does the debaffled section 3 sound? Also, was this a DIY?Originally posted by davidinnyc View Post1. IND-painted corner reflector covers installed.
2. SCZA Section 3 removed (now for sale).
3. Debaffled OE Section 3 installed.| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
Threw on the decal on my airbox!
IG: @limited.slip
Alpine White E90 M3 6MT
Alpine White 1 Series M
T̶i̶t̶a̶n̶i̶u̶m̶ S̶i̶l̶v̶e̶r̶ E̶3̶9̶ 5̶4̶0̶i̶ M̶-̶S̶p̶o̶r̶t̶ T̶o̶u̶r̶i̶n̶g̶ S̶6̶2̶ 6̶M̶T̶
- Likes 7
Nice one! Mine arrived in the mail yesterday!Originally posted by fattycharged View Post
Yurkan 6pt finally installed
How was the install? Fairly straightforward?
It actually sounds pretty great, to be honest. I would want it to be more pronounced when moving through the higher rev ranges but it sure does beat the stock backbox.Originally posted by siamkazi View Post
I bought it from someone local because I needed an OE Section 3 when pulling off the SCZA muffler from the newer Imola I picked up, and it was only $200.
I might actually go through the process of opening up another Section 3 and fiddling around with one design I found on M3cutters… too many projects!
I've got a spare section 3 in my garage because it was for sale for $6 and at that price I couldn't not buy it. I've wondered about doing this, would be keen to hear how it goes if you do do this.Originally posted by davidinnyc View Post
Depends how many beers you've had before you decide to install it…Originally posted by karter16 View Post
I cheated a bit, I ordered two, a Dusan Strutworks and the Yurkan. The DS came with the hollow bolt, hole saw, etc, so the rear took zero effort, the front you actually need to measure, unless you've fully dropped the subframe and are able to drill a pilot from below. Overall, straightforward either way.
I had already done bottom plates, so I didn't drop the subframe, I cut the stock rear bolts and used them for the front mount threads.
I've got the Dusan for sale, figured it would be easier to sell as it's powder coated nicely and I really don't care about the aesthetics. I'll probably just clear coat this one as is.
Holy Moly, I didn't even know this 'mod' existed, i had an exhaust prior, hated the drone and couldn't hear the csl box so went back to stock....could this be the perfect solution?Originally posted by davidinnyc View Post
If you do start another service, count me in!| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
now if someone would just produce those bends and sell them to us all at a reasonable price....I could use that spare stock box taking up real estate in my garageOriginally posted by Gt4 View PostI also have a spare that I am looking to modify like this and I will also replace the 4 tips for bigger/ longer one.
