Finished vinyl wrap (should've let the pro's do it), replaced all rubber moldings/trim, new badges all around & added carbon fiber mirrors. Couple more things to replace then next will be interior refresh and M6 SMG illuminated shifter!
Originally posted by SliM3 View PostFinished vinyl wrap (should've let the pro's do it), replaced all rubber moldings/trim, new badges all around & added carbon fiber mirrors. Couple more things to replace then next will be interior refresh and M6 SMG illuminated shifter!
Originally posted by SliM3 View PostFinished vinyl wrap (should've let the pro's do it), replaced all rubber moldings/trim, new badges all around & added carbon fiber mirrors. Couple more things to replace then next will be interior refresh and M6 SMG illuminated shifter!Build thread: Topaz Blue to Shark Blue​
KPFM Gloss Opulent IndigoBuild thread: Topaz Blue to Shark Blue​
Originally posted by BIllybilly2 View PostGot my Hamann DTM spoiler fitted, this might have been the last NOS spoiler out there.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by Ahmed.Alghoul View Post
Where did you get this bracket on the last photo .
RHD post-2003 models have a 'drug bin' on the right side of engine bay (when facing the engine). There is one mounting thread for earth and another thread seemingly made to mount the bracket :-)
The SMG pump fits snugly in this space (I put some adhesive damping at the back and on the floor so it wouldn't rattle)
I used 450mm brake hoses with 90 degree fittings both ends
Originally posted by poss View Post
COVIDD-19 Project. I made it from scratch with 2mm galvanized steel and some help from the boys at local body shop with a bending press - also note the foot on the bottom made of some bits of aluminum angle
Very nice. Where did you source the brake lines? And did you just re-pin the connector to make it longer? Or cut it and extend it?
On a RHD the SMG umbilical does not need extending - it is easily rerouted to the relocated SMG pump 'drug bin' without modification, making a RHD SMG pump relocation easier and cheaper than on a LHD (save for having to make a custom mounting bracket because there's no OTS kit available for RHD)
(You still need the CSL hydraulic fluid reservoir and mounting bracket of course)Last edited by poss; 10-21-2020, 12:18 PM.
