    Finished vinyl wrap (should've let the pro's do it), replaced all rubber moldings/trim, new badges all around & added carbon fiber mirrors. Couple more things to replace then next will be interior refresh and M6 SMG illuminated shifter!
    Click image for larger version  Name:	M3_newlook.jpg Views:	0 Size:	89.6 KB ID:	63006
      Got my Hamann DTM spoiler fitted, this might have been the last NOS spoiler out there.
        How long did it take you to wrap the car?
          Sadly, a couple months of weekend work. Tedious and definitely a learning curve on some the more complex curves.
            Looks awesome!
              What color is it? Looks like Interlagos Blue...
                Looks awesome!
                Thanks eacmen!!
                  KPFM Gloss Opulent Indigo
                    Well done. Looks killer.
                      What color is that? Daytona violet? Looks awesome.
                        Originally posted by Ahmed.Alghoul View Post
                        Where did you get this bracket on the last photo .
                        COVIDD-19 Project. I made it from scratch with 2mm galvanized steel and some help from the boys at local body shop with a bending press - also note the foot on the bottom made of some bits of aluminum angle
                        RHD post-2003 models have a 'drug bin' on the right side of engine bay (when facing the engine). There is one mounting thread for earth and another thread seemingly made to mount the bracket :-)
                        The SMG pump fits snugly in this space (I put some adhesive damping at the back and on the floor so it wouldn't rattle)
                        I used 450mm brake hoses with 90 degree fittings both ends
                          Thanks, yeah it is Daytona violet
                            Very nice. Where did you source the brake lines? And did you just re-pin the connector to make it longer? Or cut it and extend it?
                              Hel Performance made the 4 custom stainless steel braid hydraulic lines (around $230 AUD).
                              On a RHD the SMG umbilical does not need extending - it is easily rerouted to the relocated SMG pump 'drug bin' without modification, making a RHD SMG pump relocation easier and cheaper than on a LHD (save for having to make a custom mounting bracket because there's no OTS kit available for RHD)
                              (You still need the CSL hydraulic fluid reservoir and mounting bracket of course)
                                Installed Coby Wheel and wrapped lower trim to match Titan Shadow. 3M Matte Charcoal Metallic is a 99% match!
