    VANOS Oil Line: Are we replacing with Genuine part, or some other aftermarket piece?
      The genuine part was revised at some point, not sure when.
      I bought a genuine years ago but they are so expensive now a Bimmerwold or Rogue would be the way to go all things considered, $50 vs $330.​
        If the original line with one tab is install as described in TIS, it should be fine. Some of the failures might be down to not installing it properly and putting tension on the line. TIS gives three steps to install that line.
