VANOS Oil Line: Are we replacing with Genuine part, or some other aftermarket piece?
The genuine part was revised at some point, not sure when.Originally posted by PSUEng View PostVANOS Oil Line: Are we replacing with Genuine part, or some other aftermarket piece?
I bought a genuine years ago but they are so expensive now a Bimmerwold or Rogue would be the way to go all things considered, $50 vs $330.2004 Silbergrau Metallic 6MT
If the original line with one tab is install as described in TIS, it should be fine. Some of the failures might be down to not installing it properly and putting tension on the line. TIS gives three steps to install that line.Originally posted by PSUEng View PostVANOS Oil Line: Are we replacing with Genuine part, or some other aftermarket piece?
Ok so after deep diving on several things over the last few weeks I’ve come to a crossroads.
I’m a heavy DIY person, and the last oil leak to tackle on this car is the FMS.
Most of the threads say it’s a pain in the ass, and without taking the timing cover off - it’s even harder.
People routinely have said they went through/ ruined several seals before getting it installed correctly.
Problem is, it’s not a $6 seal anymore so I’m a bit trepidatious.
I’d like to avoid taking the entire timing cover off to do this, and also avoid sourcing/ buying a special tool that I’ll literally only use once. Thoughts?
heinzboehmerOriginally posted by lukasss View PostOk so after deep diving on several things over the last few weeks I’ve come to a crossroads.
3D print or have someone 3D print a tool for you - https://nam3forum.com/forums/forum/c...-install-toolsOriginally posted by lukasss View PostOk so after deep diving on several things over the last few weeks I’ve come to a crossroads.
Corteco (OE for BMW) seal is about $14 and you should only need one, maybe two with the tool. The crappy part is if it leaks for whatever reason, those four TTY bolts are not cheap. A good DIYer should be able to handle this without issue.
It is a pain. See here for my most recent experience: https://nam3forum.com/forums/forum/m...661#post309661Originally posted by lukasss View PostOk so after deep diving on several things over the last few weeks I’ve come to a crossroads.
I’d like to avoid taking the entire timing cover off to do this, and also avoid sourcing/ buying a special tool that I’ll literally only use once. Thoughts?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Somehow I don't know anyone with a 3D printer, but I cant imagine it being hard to find locally. Thank you!Originally posted by Slideways View Post
I bought 1 OE and 2 Corteco seals just in case. The bolts are definitely annoyingly priced, no doubt.
Man, looks to be. Some solid info in there. I'm going to PM you with a question or two if you don't mind.Originally posted by heinzboehmer View Post
Hey fellas - I have an SMG, and the car turned off on me unexpectedly yesterday. Good thing I was near my house, and I was able to quickly restart the car. I did some research and suspect it may be related to the "salmon relay" so I ordered one. I also want to get a good scanner/coder to diagnose the issue and future issues. I'm reading online that there are Bluetooth coders that will work with smartphones now. Any good scanner/coder that you of to recommend?
Carly is good but it isnt free, yearly subscription.Originally posted by Marc E46M3 View PostHey fellas - I have an SMG, and the car turned off on me unexpectedly yesterday. Good thing I was near my house, and I was able to quickly restart the car. I did some research and suspect it may be related to the "salmon relay" so I ordered one. I also want to get a good scanner/coder to diagnose the issue and future issues. I'm reading online that there are Bluetooth coders that will work with smartphones now. Any good scanner/coder that you of to recommend?
I've been struggling with an Autosolutions SSK installation. Finally got the shift arm carrier inside the transmission ears and it looks to me like it's 99% aligned but the pin won't go in. Any tips to get the last 1% adjustment?2001 TiAG M3 - 6mt Coupe, Anthracite Impuse - SOLD
What replacement options do we have for the gas pedal? I'm getting a consistent limp mode on the track car that has me stumped.112 70 YES Pedal-position sensor, comparison fault 06 B5 08 09
So far I've only replaced the pedal with a 60k mile unit off Ebay but the code persists. Do we need a particular pedal for the M3? The 60k unit was off a random E46 PN: 35406753518. The original pedal on my car was PN 35406762480. Although the PN shown on real OEM is 35426786281.
All of these are different and would make me believe that this pedal should be interchangeable between cars. Even the Bimmerworld listing shows all E46 models as compatible. Would our cars specify this issue being a TPS fault? Or does it just point to pedal sensor regardless?
Any help here is appreciated!
If it is not the pedal, it could be one of the other TPSs. After that, I would check that the throttle actuator plastic rod end joint does not have play or a crack in it.Originally posted by Darbshaw View PostWhat replacement options do we have for the gas pedal? I'm getting a consistent limp mode on the track car that has me stumped.112 70 YES Pedal-position sensor, comparison fault 06 B5 08 09
All E46 pedals are the same (other than autos which have a removable kickdown switch) with certain part numbers being superseded. 518 should work. If there is 30 day returns, you can try another pedal.
Edit: First try what karter16 posted below.Last edited by Slideways; 05-25-2026, 03:39 PM.
The pedal has two position sensors in it, one that measures a 0-5V range and the other measures a 0-2.5V range. The DME compares the readings from the two to ensure that they both agree on the position of the pedal.Originally posted by Darbshaw View PostWhat replacement options do we have for the gas pedal? I'm getting a consistent limp mode on the track car that has me stumped.112 70 YES Pedal-position sensor, comparison fault 06 B5 08 09
When you swapped the pedal did you do the adaption/learning process? as I think the DME has to learn the ranges the new pedal is reporting.
Second thing would be to look at the actual values the DME is seeing from those two sensors and see whether it's that they're not quite aligning, or no signal at all from one of them (could point to wiring issue), etc.
