    that's good to know. I bought a tap and die set after I did my seat a few week ago. 1 bolt was starting to crossthread but taking the tap to hole and die to the bolt to clean up the threads made it thread in much easier. I also saw the seat bolts were "NLA" so that pushed me to buying the tool set.
    Could have been old stock I guess — probably wouldn’t hurt to grab some spares if you can find them. Not that they’re that special I guess, McMaster Carr would probably do just fine for some high grade 10x1.5 bolts of the appropriate length.
      yeah, I went with a Grade 12.9 SHCS when the Torx seat belt bar bolt stripped out doing the same job lol.
      2007 GX470
      build/journal
      ig: @zzyzx85
        How do you like the 4:10? I’m on the fence about it but not sure I would feel about all the extra shifting.
        Had a shake down at lime rock park with the new 4.10 and epic tune. Constantly in the power band. Looking at data I'm pulling vs. stock on all straights even with slower exit speed. Was able to match times with 8/10ths corner speed. It was cold and had no grip in the high speed corners. At watkins glen the 4.10 and tune should net me well over a second of lap time...if not two. Feel like I'm cheating.
        I would never run the 4.10 in the street car.
          Did some cleanup under the hood and replaced some rusty bolts & nuts. Replaced Vanos filter and o rings
ID:	164158 Click image for larger version
ID:	164161 Click image for larger version
ID:	164166 Click image for larger version
ID:	164159 Click image for larger version
ID:	164167 Click image for larger version
ID:	164183 Click image for larger version
            Installing MAP sensor (covid-19) as part of my CSL intake project & Vanos rebuild/lockdown project.
            '01 M3, JB/IR, SS, TCK DA, Apex, TMS CSL, HTE, 4:10 gears - original owner
            '00 slicktop Touring converting to full M3 Touring
              Got it delivered back home!
                I'd mod the kubota next.
                  Looks great! Looking forward to seeing you put it back together in your build thread.
                    My seat is probably better than yours....
                      Killer, just killer. Will you be too scared to drive it after all this effort and expense?
                        🙂 love this idea
                        Thanks will get that updated soon. It's overdue...
                        Probably! Trying to make a rally in early June tho, so the clock is ticking. Will go from paint to a 1.5k mile trip. 😬😬
                          Dig the CSL bits!
                            Dig the CSL bits!
                            thanks!
                              Guess I missed it, what color did you go with? Looks great.
                                Thanks man. I went with Shark Blue which is a Porsche color.
                                In the early 2000s when the E46 M3s started hitting race tracks, I saw a Laguna Seca Blue M3 ripping around Road Atlanta. Shortly thereafter, another one was doing the same at Summit Point. And then another at VIR. For a stock car on street tires, it absolutely blew me away how fast it was on track. Although I wasn’t driving on
