    Where was it wiggly?
    If VANOS test passes then you're good. Curious to see what your VANOS adaptations are too
    It has some wiggle at the joints of the bridge. The alignment pins have good tolerance in the bridge holes and the cam holes.
    Edit: I’ll update with VANOS adaptations after I get some miles on the car.
      Not an M3 but pretty cool job going on with some M6 headers, wish it was mine.
ID:	195706 Click image for larger version
ID:	195708 Click image for larger version
        Fixed the Volume Knob On-Off​ on the CD53 unit using a 3D printed replacement from Lithuania
        Click image for larger version  Name:	IMG_5696.jpg Views:	0 Size:	39.7 KB ID:	195711
          You can buy from this site if you are located in USA.
            I blast one of my diff alu cover, looks like new now!
              Looks fantastic!
              It's too bad they don't offer bushings for these housings.
                Looks fantastic!
                I think you can use E36 M3 bushings
                  Seriously?! If so that's gonna save me some coin.
                  Are they the E36 M3 diff cover bushings?
                    Yes, I have them on one of my M3. Maybe someone else can confirm?
                      Yeah supposedly softer durometer though
                        Hmmm...
                        I wonder how much softer they are. Right now I have aluminum bushings (Turner) so there's that. I wouldn't care except for the bloody diff whine...
                          What would the drawback be of using the sofer E36 bushings if any?
                            I have them. Can’t tell the difference except less SMG clunk. I bought the car with 60k on the clock so I can’t compare them with new. That is, these feel new to me.
                            maw
                              The way I see it for my street car, I installed CMP aluminum raising subframe mounts and the E36 M3 diff bushings. OEM subframe bushings were rubber and moving but E46 M3 diff bushings are stiffer (when new
                              maybe!). In the end, the car feel tight now.
                                Learn something new on this forum everyday. I might order up the E36 bushings and try to press them in. Thanks for the info.
