Originally posted by heinzboehmer
Oh really? That really doesn't make sense then. It works for smg cars converting to CSL though I think.
You can use it to mount the reservoir but need to make a little bracket: https://nam3forum.com/forums/forum/m...tting-too-high2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by discoelk View PostAmbient air temperature sensor on the passenger side? Idk if RHD cars or non US stuff has the sensor there instead. My car had an extra passenger side connector when I had the bumper off.
The OEM fender liners have a cut out for the sensor on both sides iirc.
Looks like we are neighbors.
D-OOld, not obsolete.
Further investigation confirms no other connections on the washer bottle and no air temp sensor. I had another good look at the connector with a flashlight and it is so dirty on the inside that there is no way it could have been connected to anything. Looks like Casa was correct, the harness was manufactured to support vehicles both with and without the high pressure pump.
Originally posted by cobra View PostDoes anyone know what type of fastener (and part number?) goes here? Located just to the left of the ECU (viewed from the front of the car). It holds the divider panel between ECU and engine bay areas.
https://www.ecstuning.com/b-genuine-...h/51718204904/
Part #16:
https://www.realoem.com/bmw/enUS/sho...diagId=51_3276Build thread: Topaz Blue to Shark Blue
Originally posted by AWE46M3 View PostDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Heres a legitimate dumb question, has anyone here ever won anything on ECS's "spin to win"?2004 Silbergrau Metallic 6MT
Thank you 🤝 Rusty, but not falling apart. Appreciate it2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by jayjaya29 View PostOne of the worm clamps that connects the ITB to the rubber coupler has failed on cylinder 4. Is it possible to snake in a new worm clamp without removing the whole intake manifold? Can I simply loosen the other 5 worm clamps and pull the intake mani back to fit the new clamp?2004 Silbergrau Metallic 6MT
