    To be super pedantic, the CSL doesn't have that stud at all. Instead, it has a bracket for the reservoir spot welded to the strut tower: https://youtu.be/R3UjysWV3PA?t=839
    Not entirely sure what the stud is for, but it's there on all E46s (I think and except for CSLs). Not used on the M3s
    Oh really? That really doesn't make sense then. It works for smg cars converting to CSL though I think.
      The stud that's already there is a bit too far into the engine bay. Reservoir interferes with the intake if it's used as a mounting spot.
      You can use it to mount the reservoir but need to make a little bracket: https://nam3forum.com/forums/forum/m...tting-too-high
        Ambient air temperature sensor on the passenger side? Idk if RHD cars or non US stuff has the sensor there instead. My car had an extra passenger side connector when I had the bumper off.
        The OEM fender liners have a cut out for the sensor on both sides iirc.
        Thanks. I will check it out along with the washer bottle.
        Looks like we are neighbors.
        D-O
        Old, not obsolete.
          Further investigation confirms no other connections on the washer bottle and no air temp sensor. I had another good look at the connector with a flashlight and it is so dirty on the inside that there is no way it could have been connected to anything. Looks like Casa was correct, the harness was manufactured to support vehicles both with and without the high pressure pump.
          D-O
          Old, not obsolete.
            Hey Group,
            Purchasing new OEM exhaust hangers and wondering if this part is necessary. Pretty pricey 😳 Mine appear to be the original ones and 120k miles later they are pretty rusty.
            Part # 10 in the realoem diagram:
              Does anyone know what type of fastener (and part number?) goes here? Located just to the left of the ECU (viewed from the front of the car).
              It holds the divider panel between ECU and engine bay areas.
              Click image for larger version  Name:	screw.jpg Views:	0 Size:	181.5 KB ID:	196134
                Does anyone know what type of fastener (and part number?) goes here? Located just to the left of the ECU (viewed from the front of the car). It holds the divider panel between ECU and engine bay areas. Click image for larger version Name:	screw.jpg Views:	0 Size:	181.5 KB ID:	196134
                Here you go:
                https://www.ecstuning.com/b-genuine-...h/51718204904/
                Part #16:
                https://www.realoem.com/bmw/enUS/sho...diagId=51_3276
                  Hey Group,
                  You don't need new ones unless yours are so rusted they're falling apart or you just want new ones.
                    Heres a legitimate dumb question, has anyone here ever won anything on ECS's "spin to win"?
                      Not me!
                        Thank you. I think the same freaking thing every time they come out with this whole spin the wheel horse crap.
                          Thank you 🤝 Rusty, but not falling apart. Appreciate it
                            Throw them in some evaporust and then paint them, good to go
                              One of the worm clamps that connects the ITB to the rubber coupler has failed on cylinder 4. Is it possible to snake in a new worm clamp without removing the whole intake manifold? Can I simply loosen the other 5 worm clamps and pull the intake mani back to fit the new clamp?
                                Most worm style clamps can simply be "unwound" all the way without issue, just be careful not to bend the clamp up too much and you'll be fine.
